D17 tach cable drive adaptor
Chris (swIA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris (swIA) Quote  Post ReplyReply Direct Link To This Post Topic: D17 tach cable drive adaptor
    Posted: 11 Feb 2011 at 1:22pm
I need to repair or replace the adaptor that goes from the end of the govenor shaft to drive the tach cable? Does anyone have one that they would part with or has someone repaired one? The tach cable was gone when I got this tractor and I assume that the cable seized and that is what broke the tab off the end that fits in the shaft. This is on a series 1 gas with power steering.
paulinkansas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulinkansas Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2011 at 1:58pm
Search my old posts.  I found one at Autozone.  It was around 10 bucks.  It wasn't in stock though, got it the next day.
David(Stockbridge)MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David(Stockbridge)MI Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2011 at 2:34pm
Have the complete 2 piece set in stock. The MSD8491 will not work because it only has a square hole. Stock cable has a key that fits into the adapter.
All "NEW" Web Site http://www.djstractorparts.com
2035,A,U,UC,WF unstyled,WF styled,WC High Crop (cane),RC,B,IB,C,CA,WD,WD45,G,D10,D12,D14,D15,D15 II,D17,D19,WC styled,WC unstyled H3 crawler
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2011 at 3:49pm
I have a D-14 tach cable with a good end on it if that will help.
This page was generated in 0.430 seconds.
