D17 steering |
D171958 ![]() Bronze Level ![]() ![]() Joined: 03 Aug 2024 Location: Iowa Points: 68 |
![]() ![]() ![]() ![]() ![]() Posted: 28 Dec 2024 at 8:44am |
Good morning everybody. I was wondering on my d17 series 1 when I took the front pedestal off and the retaining plate there was 2 different kinds of gaskets 1 was a steel shim and the other one was a Valium shim but there was at least 3 of each, and when I order parts from agco them 2 part numbers only say I only need 1 of each just wondering how I should put it back together. Thanks
AC720Man ![]() Orange Level ![]() ![]() Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5243 |
As long as they were not damaged, clean them and put it back together in the same order they come off. I did my D17 and presently doing my D14 that way. I’m installing PS in my D14.
Edited by AC720Man - 28 Dec 2024 at 9:42am |
Ok thanks I didn’t read far enough in my manual to read it so it’s my bad.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 22021 |
Every tractor is different for total count. That's why they are called shims. The design is (ideally) a paper shim on each side of a steel shim so it doesn't leak oil.
Ok will need to get more then.
WHY ??? After 50+ years of operation, why would you want to change the shim stack thickness ?? or do you have damaged paper shims ??
The paper shims are very fragile, gentle removal of parts are required as well as the proper sequence of all shims during reassembly. This gives the proper clearance's of the bearings to their bearing cup. I’m sure there is a term for this but it eludes me at this time. It is the reason for me using my front support and internal parts along with the idle gear and power steering parts from the parts tractor front support. The bearings on the steering shaft of the donor front support were damaged and I had no way of measuring and getting those dimensions for proper fitment.
Edited by AC720Man - 29 Dec 2024 at 9:47pm |
The steering shaft sector that I am referring to is on the left. Both bearings are damaged due to water in the front support. Bearing cup in the front support and the other bearing cup in the shaft retainer. Those shims provide the proper clearance for both bearings.
Edited by AC720Man - 29 Dec 2024 at 10:05pm |
Yes when I took mine apart it ripped some of the paper shims and the bearings were bad in it. This tractor before it’s all done will just about have every bolt and nut taken apart.
