D17 Spindle Removal? |
AaronSEIA
Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2574 |
Topic: D17 Spindle Removal?Posted: 18 Jan 2024 at 5:39am |
Snapped a spindle on my D17 S2 the other day. Any tips/tricks to getting the steering arm off? Really don't have access to heat. AaronSEIA
Lon(MN)
Joined: 11 Sep 2009 Location: Merrill Wi Points: 2042 |
Posted: 18 Jan 2024 at 6:43am |
If it were mine I would grind off the bottom, remove the remaining spindle from the top. Set it in a press or support it so you can hammer the the rest out. I have the knee assembly on the shelf and would just replace the assembly. It gets easier when you drag home parts tractors.
http://lonsallischalmers.com
Posted: 18 Jan 2024 at 6:53am |
Remove the knee and turn it upside down and drive downward with a 20 lb or more sledge hammer. Solid blocking is important for a good hard hit.
