D17 Series IV Diesel - Narrow Front Swap
BlueBandit17 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BlueBandit17 Quote  Post ReplyReply Direct Link To This Post Topic: D17 Series IV Diesel - Narrow Front Swap
    Posted: 19 Jan 2023 at 8:11pm
I have a D17 IV diesel with power steering that was originally a narrow front but a previous owner converted it to a wide front with what I believe is a "Schwartz" front axle. I would like to convert it back to narrow front at some point.
Question: Will any Series D17 narrow front work on a series iv?
Would a diesel have a different narrow front than a gas?
Thanks in advance
1965 D10 Series III
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2023 at 8:24pm
Any series should work.                      MACK
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2023 at 7:06am
Only any D17 or D19 will work. D19 is 2" taller. D14/15 are shorter and have a different spline. I have a D17IV diesel that I installed a narrow front on. Used a D19 to get the tractor to sit level because it has 14.9 x 38 rears .
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2023 at 7:38am
D-19 and One-Seventy's use the same taller NF post.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BlueBandit17 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2023 at 10:00am
Thank you for the help. I had thought I read somewhere that there was some change to the series iv pedestal, whether through different bearings or something, but this may not be correct.
Thanks again!
1965 D10 Series III
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2023 at 7:52pm
D17 Series III and IV have a different heavier wide front axle but the bolster is the same as earlier D17's
