D17 Series IV Diesel - Narrow Front Swap |
BlueBandit17 ![]() Bronze Level ![]() ![]() Joined: 04 Nov 2022 Location: Falcon, NC Points: 4 |
![]() ![]() ![]() ![]() ![]() Posted: 19 Jan 2023 at 8:11pm |
I have a D17 IV diesel with power steering that was originally a narrow front but a previous owner converted it to a wide front with what I believe is a "Schwartz" front axle. I would like to convert it back to narrow front at some point.
Question: Will any Series D17 narrow front work on a series iv? Would a diesel have a different narrow front than a gas? Thanks in advance |
1965 D10 Series III
Any series should work. MACK
Calvin Schmidt ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Ontario Can. Points: 4543 |
Only any D17 or D19 will work. D19 is 2" taller. D14/15 are shorter and have a different spline. I have a D17IV diesel that I installed a narrow front on. Used a D19 to get the tractor to sit level because it has 14.9 x 38 rears .
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21987 |
D-19 and One-Seventy's use the same taller NF post.
Thank you for the help. I had thought I read somewhere that there was some change to the series iv pedestal, whether through different bearings or something, but this may not be correct.
Thanks again! |
1965 D10 Series III
D17 Series III and IV have a different heavier wide front axle but the bolster is the same as earlier D17's
