D17 series by year |
allis converted
Joined: 10 Jun 2011 Location: opolis, KS Points: 40 |
Topic: D17 series by yearPosted: 17 Jun 2011 at 8:12pm |
Hello I am looking at a D17 it is a 1959 model can any one tell me the series by years also if it is a series one how many problems have ar ethese models plagued with?
Pat the Plumber CIL
Joined: 11 Sep 2009 Location: Springfield,Il Points: 4974 |
Posted: 17 Jun 2011 at 8:59pm |
D-17 models prior to serial# 32001 are unofficially called Series 1
29988 built Series 2 started at 1960 serial # 32001 (9,540 built) Series III started at 1962 serial # 42001 (9,126 built) Series IV started at 1964 serial # 75001 and later (14,213 built) Most common "major" problem is transmission jumping out of gear.Usually 3rd or 4 th due to wear on most used gears.Drive tractor down a hill in third and fourth gear while working throttle up and down.If it pops out of gear ,can be expensive to fix. D series were very good dependable tractors and usually are very reliable.Like anything wear and neglect are the only real problems with these machines. Edited by Pat the Plumber CIL - 17 Jun 2011 at 9:00pm |
1964 D-17 SIV 3 Pt.WF,1964 D-15 Ser II 3pt.WF ,1960 D-17 SI NF,1956 WD 45 WF. |
Ryan Renko
Joined: 12 Sep 2009 Location: Edwardsville, I Points: 2338 |
Posted: 17 Jun 2011 at 9:05pm |
There was a very usefull chart posted several days back that discussed all the D17 series in great detail. Ryan
allis converted
Posted: 17 Jun 2011 at 9:08pm |
Thanks the serial number is 20202 I am looking to replace my 640 ford it is tired of mowing my six acre yard the D17 is priced at 3000 but I can get it for about 2500 I think.
Lonn
Posted: 17 Jun 2011 at 9:10pm |
Series I = 1001 thru 31625 (1957-60)
Series II = 32001 thru 41540 (1960-62)
Series III = 42001 thru 72768 (1962-64)
Series IV = 75001 thru 89213 (1964-67)
Not alot of difference between a Series I and II. Wider swing drawbar ? maybe started with series I black bar grill models, little heavier bull gears, built in thumb guard on PD stick, Full flow oil filter I think actually started with the black bar grill Series I models.
Can't say any D17 suffers from a plague of any kind. Edited by Lonn - 17 Jun 2011 at 9:13pm |
Wink I am a Russian Bot |
Lonn
Posted: 17 Jun 2011 at 9:11pm |
Gee, I stopped to look at a book and wham, I'm way behind Pat
allis converted
Posted: 17 Jun 2011 at 9:14pm |
Now I have to many choices the seller just called me he says for the same price he has a D17 ,IH 300 or a 860 Ford there all about the same HP so I will have to check them all out.
Lonn
Posted: 17 Jun 2011 at 9:22pm |
D17 is most versatile of the 3. Check to see if it pops out of gear, if the hand clutch has good snap and does it have power steering. Otherwise the same wear areas of any other tractor. Does it smoke, does the power steering work good, oil pressure. Pull all the dipsticks to check for water etc.
allis converted
Posted: 17 Jun 2011 at 9:26pm |
I will check them all out tomorrow morning, I have to do something quick it is pretty funny looking with a 6' woods finish mower behind a 190xt with a 500 loader on it.
allis converted
Posted: 17 Jun 2011 at 9:30pm |
Just found out he also has a WD45 with a wide front for the same price!
Auntwayne
Joined: 23 Apr 2011 Location: Edwardsville Il Points: 1589 |
Posted: 17 Jun 2011 at 9:50pm |
What is the weight of a series iv gas ?
Auntwayne
Posted: 17 Jun 2011 at 9:54pm |
Also, need a pic of the original grill mounts on a D17, (close up) would be nice . SERIES IV
allis converted
Posted: 17 Jun 2011 at 9:57pm |
Tractor data says 4670 lbs operating 9395 balasted
Posted: 18 Jun 2011 at 7:12am |
D17's in the real world never weighed 9395 lbs....that was Nebraska test weight on concrete. A series 4 with wide front and full fuild in the rear 16.9 x 28's with snap coupler hitch was around 6000 lbs if memory serves me.
allis converted
Posted: 18 Jun 2011 at 10:03am |
Well the D17 is out it jumps out of two gears and it seems a little weak on power. I guess I will have to keep looking.
Dans 7080
Posted: 18 Jun 2011 at 10:25am |
My series 1 weighs 5800lbs with 16.9-28s and fluid but no other weights.
