D17 Series 1 engine removal
PA185 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PA185 Quote  Post ReplyReply Direct Link To This Post Topic: D17 Series 1 engine removal
    Posted: 13 Jan 2020 at 9:42am
Pulling the engine out of my 1959 series 1 D17 gas with power steering. What all is involved or needs to be removed to pull the engine out? If I take the bell bolts out and disconnect the power steering lines it looks like I can pick it right up out without splitting the tractor. Other than some misc wires, lines, etc am I missing anything?
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2020 at 10:12am
Has to be split motor has to go straight forward about 8 inches to get the clutch and fly out of the bell housing
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2020 at 2:23pm
Front pedestal and frame rails have to come off.  You can move it all as an assembly if you loosen the rails at the pedestal and have 2 strong friends.  Myself and my 11 year old boy rolled the front out from under my series 2 wide front.  It'd be a LOT easier without power steering.  That cylinder made it fun clearing the front cross member.
AaronSEIA
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2020 at 6:41am
Be sure to tie the tie rods to wishbone.     MACK
This page was generated in 0.097 seconds.
