? D-17 Ser.IV Hydraulics
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Topic: ? D-17 Ser.IV Hydraulics
    Posted: 31 Aug 2011 at 9:24pm
On the back of my D-17 SIV there are 2 female hydraulic coupings on the right side(facing the back),there are 2 holes in sheet metal on left side.On other D-17 SerIV's I have seen 2 female hydraulic couplings plumbed in on both sides.
I have only used one side for the rotary mower.I replaced one on the far right side so it will match my hose end.Is the other one that I have for a "Return" or will it lift another cylinder at the same time?The other sets I have seen on other tractors,Are they for fluid to flow both ways or are they "Returns" for proper Two way hydraulics?
Sorry I do not mean to make an easy question difficult.I have never worked with 2 way hydraulics., everything I worked only had single acting hydraulics.
Thanks for any help ahead of time
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 9:35pm
The two you have on the right side is for a two way cylinder. The other tractors you have seen with another two on the left is a second remote for a second two way cylinder. Sounds like you are using a one way cylinder and that is fine.
We do the samething with our 7000 to run the batwing mower. It has three - one way cylinders. We tied into the 3pt hose to power the third cylinder.
