D17 S1 split at torque housing (PTO bushing seals)
ACthunder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACthunder Quote  Post ReplyReply Direct Link To This Post Topic: D17 S1 split at torque housing (PTO bushing seals)
    Posted: 06 Apr 2017 at 11:19pm
D17 S1 split at torque housing (PTO shaft seals and bushing)
While I have the tractor apart I should probably replace the two PTO seals and bushing correct? Looks like I could get a hooked device on the seals but how would one get the bushing out?
The PTO shaft below has some scaring from the worn out bushing I guess, do you think this should be worked on before installing with the new bushing?
Thanks,
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2017 at 5:59am
I would drive it out toward back, then fish it out through back hole.    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACthunder Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2017 at 7:10pm
That PTO bushing if $50... do you think the condition of the PTO shaft will just wear it out again?
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2017 at 9:56pm
It will unless you do something with shaft. I turned one down and made a sleeve to press on shaft. Salvage yard may have a good shaft.    MACK
Allis_1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis_1 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2023 at 11:48am
Hello,  just wondering how this repair turned out,  I have same situation and will be replacing bushing and seals soon.  Did that bushing push out the back ok?  Anything you learned to make this job easier?    Thanks
