D17 Rearend Pinion bearing |
Cooter ![]() Bronze Level ![]() ![]() Joined: 04 May 2011 Location: wisconsin Points: 1 |
![]() ![]() ![]() ![]() ![]() Posted: 04 May 2011 at 10:16pm |
How do i take apart the rearend pinion bearing on my 1958 D17? Do I need to take off the tires and work my way in on both sides on the rearend or is there another way?
Orange Blood ![]() Orange Level ![]() ![]() Joined: 29 Nov 2010 Location: ColoradoSprings Points: 4053 |
In a nutshell.....YES. You don't necessarily have to remove the wheels from the axles, but the axle housing must come out each side, and it would probably be easier to have the big bulky heavy tires and rims off, for alignment purposes.
Still in use:
Chris/CT ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Niantic, Ct Points: 1939 |
Are you talking about large bearing at outboard end of Trans pinion shaft? If so, you have lots to remove before that is exposed. Split tractor, remove transmission gears/shafts, finals off, etc, etc.
Edited by Orange Blood - 05 May 2011 at 2:47pm |
Still in use:
