D-17 rear housing
Darrell G (MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darrell G (MN) Quote  Post ReplyReply Direct Link To This Post Topic: D-17 rear housing
    Posted: 03 Mar 2010 at 6:45am
I am looking for a rear housing for a D-17 series 2 or the entire rear clip. thanks
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2010 at 6:49am
There is one sitting in CT here at friends shop, let me know if would like his contact info. He does have trucks on the road, maybe able to help with delivery.
Slade (TN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Slade (TN) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2010 at 8:09am
I have a ser III here in TN Darrell......if that helps....course it's a looong trip for a '17 rearend.
Slade
615-542-6999
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2010 at 8:24am
Darrell - might want to check the Worthington salvage yard in MN.  If you go to a Series III or IV rear you need to upgrade to the new style band-acutated disc brakes.
There were FIVE different housing used across the four series with SN breaks at 1) before 240001 2)24001 to 38898 3)38899 to 42000 4) 42001 to 75000 5) 75001 & up. If you use one of the later housings to replace a tractor before SN 38899 there is a list of transmission input shaft and related parts that must be updated as the newer housings after SN38899 & up were updated to a double row ball bearing on the front bore.  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Terry View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Terry Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2010 at 8:27am
may have a rear end assy in about a month or so don't know if series 2 or not , would be in eastern  S. D. If interested Call  605 - 886 7198  thanks Terry
Troy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Troy Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2010 at 12:34pm
darryl can you give me a casting number i should have just a rear housing for a early d17, call me 507 421 0213, troy south minnesota.
niel ev View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote niel ev Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2010 at 12:58pm
We have a couple of rearends here in various states and I thing the last one we pulled the engine out of was a series 2 if you get me our serial number I'll see how close I can get to yours Niel
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2010 at 2:54pm
Ive got one Darrell, housing has diff and trans gears in it, I dont know the s/n for sure but it has a 3 bar grille.   You can have it for haulin the lawn tractor back from Indiana if thats ok.  I wont be able to bring it until some snow melts so I can get the pickup out, or you can come and get it.   Lemme know!!!
Gary(OR) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(OR) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2010 at 3:44pm
I've got one also, late series II.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darrell G (MN) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2010 at 8:02pm
Skip, please send me your phone number again, I misplaced it, a memory is a terrible thing to lose
AndyinWI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AndyinWI Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2010 at 9:27pm
I have one too that i don't want sitting around!
