D17 Pwr Steering & Pump Rplmnt with/Priority Valve
nowaktj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Topic: D17 Pwr Steering & Pump Rplmnt with/Priority Valve
    Posted: 09 Sep 2010 at 5:08pm
Hi
Here is a link to a priority valve on Steiner:
It looks like this device can be used to operate your power steering off of the Live Hyd pump.  It says it would work on WD models.
By doing this i t:  "ELIMINATES BELT DRIVEN PUMP, PULLEYS & BRACKETS. ENABLES YOU TO USE YOUR LIVE HYDRAULIC PUMP TO OPERATE THE POWER STEERING."
Has anyone done this?  Would it also work for a 1958 D17 tractor?
Thanks in advance for the help,
Terry
D19D, D17D, WD, WC, Snobee, #83 Plow, SC Blade, 14' disk, 400 series planter, B , Terra Tiger, M Dozer w/Baker Blade, TL-12, 42S Grader, G
Harry up of Mi. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Harry up of Mi. Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2010 at 6:56pm
These valves work great. I installed one on my sons D-14 along with a char-lynn torque generator. He has used it for about a year with no problems. Northern Tool has them for $95.00 plus shipping, [item no. 2049-1101]
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2010 at 8:37pm
Something to remember, if the pump is putting out 4 gpm or less, the priority takes it all.
The valve works great if you have a large enough pump, as in a front mounted pump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2010 at 8:47pm
The instant you step on the clutch, you will have no power assist.
