D17 oil leak
vyvyjim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote vyvyjim Quote  Post ReplyReply Direct Link To This Post Topic: D17 oil leak
    Posted: 21 Oct 2010 at 3:06pm
I just purchased a series IV D17 and it is my first restore.
1.  Oil leaks on the right side where the PTO lever comes out and possibly from where the foot clutch shaft comes out.  What is involved in fixing this?
2.  Oil leaks at the rear of engine.  How do I tell if it is the pan gasket or the rear seal?
3.  I need the bracket that attaches to the steering column and hold the back of the gas tank down; anyone have one?
Thanks so much,
Jim Vyvyan
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2010 at 9:38pm
1.  Clutch shaft will never leak - no seals.  PTO seals are known for leaking.  Remove the inspection plate on the right side, pound out the roll pin that the PTO lever attaches to, pull out the handle, replace the o-ring, then put it all back together.  Tough part is playing with the roll pin!
2. Remove the clutch inspection plate on the bottom of the torque tube.  Stick your finger up there - if it feels oily, your rear seal is gone.  If not, it's probably your oil pan gasket.
3.  Can't help you with that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote vyvyjim Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2010 at 2:24pm
Thanks so  much!
