D17 Location of timing slot
kerrdawg40 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kerrdawg40 Quote  Post ReplyReply Direct Link To This Post Topic: D17 Location of timing slot
    Posted: 30 Apr 2010 at 4:54pm
There are 2 slots on top of bellhousing about 1 inch long and about an 1 inch apart from each other . Underneath is a hole in the very center. Is it one of these or am I missing something. D171590 is the serial # on the housing. Thx----Oh and how is the timings marked. Thx
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2010 at 5:09pm
its marked on the flywheel if its still there F here is the kicker .  the F for tdc will be in the center of the hole on the bottom for serial numbers 17-19978 .  17-19978 and up the tdc F should appear at top of the timming hole  . they set at 30degrees btdc factory prior ones set at 25 before tdc.
operators are standing by at two drunks garage to take orders for hei replacement distributors. well i am setting by to lazy to be standing. Man that motivational film has changed my life.
