d17 loader
Bluetick58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bluetick58 Quote  Post ReplyReply Direct Link To This Post Topic: d17 loader
    Posted: 16 Jan 2025 at 2:19pm
is there anyway to keep 3 point up while dropping loader, blade on back drops as soon as loader on d17?
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2025 at 7:26pm
I made a piece for a guy once that sat on the drawbar and went to the top link on the 3pt attachment to hold it up. Not convenient, but effective.
tractorboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorboy Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2025 at 7:49pm
I use a small chain attached to seat bracket to hold up the arms "no implement" .   My buddy plumbed a cut off valve mounted to the fender on his D15 ,bit I think that's to isolate the loader when he uses the 3point.  keith so va.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2025 at 9:03pm
The easiest way to have the most useful results is to install a Diverter Valve in the Steel Hydraulic Line that runs from the left side of the Torque Tube to the top of the L/H Rear Axle Housing.
Allis had an Optional Valve that mounted on top of the housing and connected to the threaded Port that feeds the Internal Lift Cylinder.
This was a Push / Pull Diverter Valve so you could feed either the Rear Lift OR the Loader.
The Loader normally connected to the rear of the Valve via a Quick Disconnect.
G
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bluetick58 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2025 at 6:06am
Thanks guys
