D17 LOADER QUESTIONS
irunjohndeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote irunjohndeere Quote  Post ReplyReply Direct Link To This Post Topic: D17 LOADER QUESTIONS
    Posted: 08 Mar 2010 at 6:04pm
I am looking to put a loader on my Allis Chalmers D17, Series 3, and after reading numerous posts on here I just want to make sure I understand correctly.
1.)  400 and 500 Series loaders will fit on a D17 without any modifications?
2.)  The 400 Series loader came with a front hydraulic pump and oil storage in the left hand side of the loader frame?
3.)  To run a loader independent from the rest of my hydraulic system on my D17, Series 3, I have to have a loader with the front hydraulic pump?
Now I have a few questions.
1.)  Are the 400 and 500 Series loaders the only Allis Chalmers loaders that tilt cylinders for the bucket and will fit a D17, Series 3?  Or are there others?
2.)  Besides the 400 Series, is there any other series of loaders made by Allis Chalmers that has the front hydraulic pump that would fit my D17, Series 3?
3.)  I know where there is a Model 17 or 217 Allis Chalmers loader that I have been told would fit my D17 but it has a trip bucket and if I understand right there would be no way to modify it to work with my D17 because I only have one hydraulic output.  Is that right?
Thanks for your time and help.  Also anyother info you want to share about putting a loader on my D17 would be greatly appreciated.
Edited by irunjohndeere - 08 Mar 2010 at 6:07pm
E7018 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote E7018 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2010 at 7:22am
I have a drive setup for a front pump that I took off. Your on your own as to a mount and pump because this one had a hydraulic oil reservoir in front of the radiator, that would be in the way for a loader.
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2010 at 8:56am
Not all 400 series loaders had the built in oil storage tank built on them,
Any loader you put on your d17 series 3 will require you to run an auxilary pump for 2 way hydraulics.
you would have no problems with a model 17 loader on your tractor. but it will only have "1 way" hydraulics,
Denis in MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2010 at 1:29pm
You could always put on a remote valve with three spools, two for the loader and one for the lift arms
Kinda like this but with a three spool valve, that way you can run a hydraulic bucket, have down pressure and une your rear lift all at the same time.
1938 B, 1945 B, 1941 IB, 1949 C, 2 1938 WCs, 3 1950 WDs, 1951 WD, 2 1955 WD45, 1957 D-14
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2010 at 4:30pm
My D17 diesel has the optional 3 spool valve, which you could run two remote cylinders besides the lift arms.  Those are tough to find and they did work ok, the main drawback there was you needed low volume/high pressure cylinders on the loader.  the valve Denis has pictured looks good, just need a three spool valve and it does get kinda cramped for space back there.
This page was generated in 0.075 seconds.
