D17 Hydraulic lift arms not staying up
FOOT1959 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FOOT1959 Quote  Post ReplyReply Direct Link To This Post Topic: D17 Hydraulic lift arms not staying up
    Posted: 17 Feb 2011 at 11:55am
I'm having problems with my 57 D17 lift arms not staying up. matter of fact they wont even raise after the first time anymore. The only two things i could think of is the cylinder is leaking past the seals or the hose going to cyl. is ruptured. after one lift the reservoir  is low and the trans fluid is higher. any advice or input would be appreciated.
sandylakeimplement View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sandylakeimplement Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2011 at 11:59am
Since you are transferring oil from hyd sump to tranny I would bet that your suspicions are 100% on the money. Might as well replace seals & hose while apart, rear PTO seal too.   Bill
Sandy Lake Implement
Sandy Lake, PA
724-376-2489
www.sandylakeimp.com
FIND US ON FACEBOOK
Post Options Post Options   Thanks (0) Thanks(0)   Quote FOOT1959 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2011 at 12:02pm
Can the lift cylinder be gotten to by taking the lift arm housing off?
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2011 at 12:16pm
Yes,  drain oil in trans, rear end and also hyd oil.  Pull PTO shaft out the back,  then take off the lift shaft housing,  the cylinder piston will come with the housing.  should be able to see the hose and the cylinder seals,  also look for a crack where the hose attaches to the cylinder.   Good luck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FOOT1959 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2011 at 6:12pm
Thank you, Thats easier than i expected. but i know there's  always things that will usually not go as planned. Thanks again, Foot
This page was generated in 0.211 seconds.
