D-17 Governor & PS parts |
Author | |||
Stanley ![]() Bronze Level ![]() Joined: 16 Oct 2009 Location: PDC, WI Points: 193 |
![]() ![]() ![]() ![]() ![]() Posted: 07 Jun 2015 at 7:00pm |
I need governor weights, pins & thrust bearing plus some power steering parts - needle bearings, oil seals & drive shaft bearing. Any suggestions who to contact for parts?
Thanks for any help. Stanley
Sponsored Links | |||
norm[ind] ![]() Orange Level ![]() Joined: 29 Oct 2010 Location: bourbon,ind Points: 2992 |
DJS TRACTOR PARTS[MICHIGAN] 734-320-3470 TELL HIM NORM TOLD YOU TO CALL
DAVE IS HIS MANE
Thanks Norm. I'll call him tomorrow.
Brian G. NY ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: 12194 Points: 2259 |
Here is some info on the needle bearings and seal.
You may not need this because it appears that DJ's probably handles all the stuff you will require. Seals (2): A-C #0229372-8 National #450023 I.D. .625" O.D. 1.375 Thick. .406" Needle Bearings (4): A-C #0800781-7 Torrington #B-108 I.D. .625" O.D. .8135" Thick. .50" Ball Bearing (driveshaft) A-C #0229508-7 This is the very common 203S bearing used in automotive applications. Not knowing at the time the source Norm refers to, I searched around the internet for my bearings and seals except for the ball bearing which I happened to have "in stock".
Brian-KS posted this in response to your original post.
Brian-KS ![]() Orange Level ![]() Joined: 27 Aug 2014 Location: Kansas Points: 914 |
My parts have been sold, thanks
EAT BEEF!
