D17 Gas Leak
JWingerter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JWingerter Quote  Post ReplyReply Direct Link To This Post Topic: D17 Gas Leak
    Posted: 20 Aug 2022 at 11:32am
D17 Series IV (according to serial)
See two images below.
My carburetor leaks.  Would it be reasonable to expect I might fix this with new gaskets?
D17 Series III
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2022 at 12:55pm
the seat for the INLET VALVE might be cut and causing carb to overflow... YEs, new gaskets, new shut off seat ( or lapping old) , and reset the float level will fix the leak.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2022 at 4:52pm
Your carb is a Marvel Schebler, not a Zenith.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2022 at 5:14pm
Good catch Dr... I didnt even look at the name on the KIT..
you can get a BASIC kit with gaskets and seals... or you can get a KIT that includes new shafts and  valves ......... check if your throttle shaft wobbles in the bore.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2022 at 10:25pm
It's also NOT a series 4 by the carbs choke linkage.
