D-17 gas head
TexasAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TexasAllis Quote  Post ReplyReply Direct Link To This Post Topic: D-17 gas head
    Posted: 08 Apr 2011 at 10:16am
Does anyone have a drawing (cutaway) of a D-17 gas head that shows the location of the water passages?
walters444 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote walters444 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2011 at 5:50pm
no pic.,,,,,  but i might be able to help
whats up????????
Chapin Cylinder Head and Block 217-472-3333
 GIVE US A RING
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2011 at 9:03am
if your thinking on porting and wanting to know where the water is . the two places i usually hit it first at are at the bottm about a half inch in . At the top were the intake port tees or turns toward the intake valve.  Belzona 111 supermetal is your friend when doing port work on a 50 yearold porous cast iron head. some heads due to sand pits and rust over there life have real thin areas.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TexasAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2011 at 7:28am
I was thinking about building a spit manifold out of header pipe.  There are not many holes in the head to bolt a manifold to so I wanted to know if I drilled additional holes where can I drill and not hit water.
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2011 at 11:31am
Most if not all the current manifold studs go into the water jacket.....what's a couple more?
wi50 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wi50 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2011 at 12:05pm
just stay away from the ports a bit, but you won't be able to drill and put a bolt that close anyway.
I've added some manifold studs for header plates in several of the 201-226 type heads and never had a problem.  I've added extra holes around the intakes to hold a seperate fabricated intake manifold.  On one head I even put a couple holes out past the end exhaust ports for a bit of extra clamping.
here's an old pic of a manifold I made
Edited by wi50 - 11 Apr 2011 at 12:09pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote TexasAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2011 at 7:29am
Now thats what I am talking about.  A little more modifications than what I have planned but I like it.
KGood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KGood Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2011 at 9:01am
Do you guys bevel out were the spark plug goes so it's not such a sharp hole sunk in the head(on the compression side). We do just because a guy told us we need to. It kinda makes sense to do that but I wondered if that was normal practice?  The guys at Rochester head shop drilled into two water passages for putting in bigger valves before they realized it. It was on a short head all they said was sorry we need a different one.
wi50 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wi50 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2011 at 10:15am
tx allis,
you can see the studs I installed out past the end exhaust ports in that head if you look close in the picture you see a shiny stud in the end.
Kgood,
I flare the plug pockets some, it should help get the flame traveling a little easier, but alwayse wait untill the valve work has been done, sometimes they can get pretty close to the plug pockets.
This page was generated in 0.095 seconds.
