D17/G226 compression Ratio & Engine info
frnkeore View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote frnkeore Quote  Post ReplyReply Direct Link To This Post Topic: D17/G226 compression Ratio & Engine info
    Posted: 18 Jun 2019 at 5:13pm
In a thread, a while back, I said I would calculate the cup in a G226 engine and post the results. I was sent a piston, with a casting # of 229717, in the cup of the piston, it's marked 229718. It was sent to me by Strokendiesel002 and I thank him, very much.
By my measurement, the cup is 56cc and the compression height is 2.530. I guestimated the the head gasket was .040 thick and that the inside diameter was 4.18". If anyone has the actual figures, I can modify the out put but, this gets it pretty close. .040 is pretty common for thickness and with the overbore kits, at 4.125 the inside diameter has to be larger than that. I also used DrAllis deck height dimension of 12.656.
If anyone has different info from what I'm showing, or any mistakes I've made, please let me know.
I will re-verify the 56cc in the next few days. Here is the results:
Edited by frnkeore - 19 Jun 2019 at 12:18pm
Frank
1959 D17 Series I #24001+, '59 D14
'55 & '59 Ford 850 & 861
Ferguson TO 35 Deluxe, Oliver 70 and 5 more.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2019 at 7:29am
You're not too far off at that figure. A-C advertised comp ratio to be 7.25 to 1 on a D-17 engine. I think your head gasket is much closer to .060" which would bring your calculated number down a bit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote frnkeore Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2019 at 12:13pm
Doc,
Pretty much right on!
Does anyone have a used head gasket that they can measure for thickness?
Edited by frnkeore - 19 Jun 2019 at 12:15pm
Frank
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2019 at 12:33pm
have a link for that calculator?
Post Options Post Options   Thanks (0) Thanks(0)   Quote frnkeore Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2019 at 12:54pm
Sure, there are others around, too but, I like this one the best, it covers all variables.
http://www.diamondracing.net/tools/
Frank
Strokendiesel002 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Strokendiesel002 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2019 at 4:32pm
Neat! Thanks for sharing!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2019 at 7:15am
Everything except valve head standout, which technically should be covered in chamber volume, which technically doesn't apply on a perfectly flat cylinder head.
Post Options Post Options   Thanks (0) Thanks(0)   Quote frnkeore Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2019 at 9:18pm
Doc.
I did think of that but it's a variable, all by itself.
The margin will vary and the depth that you narrow the top of the seat.
Frank
This page was generated in 0.254 seconds.
