D17 Failure
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2017 at 10:47am
Originally posted by mikeks mikeks wrote:
Found the problem, or at least the start. Camshaft gear has 3 spots with the teeth chewed off. Other gears appear fine. I have pictures, but no clue how to post them.
What other problems should I look for? Any chance of the valves hitting the pistons like OrangeBlood mentioned?
Any suggestions on where to find the gear and all the needed gaskets?
The governor weights have flown apart and went through the timing gears or it did previously and a piece has been picked up by the gears. I'd sure check over all the other gears. A bent tooth on one gear will take out new teeth on the cam gear and you'll be back where you started........... don't ask me how I know.
Wink
I am a Russian Bot
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2017 at 10:51am
PS the crank gear can have a bent tooth on the back side where you'd need a mechanic's mirror to see it. Again.... speaking from experience.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2017 at 7:58pm
experience is a great teacher
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2017 at 8:18pm
Just heat your cam gear with a torch and pop it off. To put the new one on make sure the wife is out shopping, put it in the oven at 300 degrees and when it's hot slip it on the cam.
mikeks View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mikeks Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2017 at 8:42pm
Just got back in town and stepped in the shop long enough to realize the governor is missing weights. I'm not even sure how the governor works. Time to do some research!
Did get some great info from my local AGCO dealer, and found all the parts and gaskets I needed. (until I noticed the weights). Thanks again for all the great advise. Will keep you posted.
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2017 at 9:01pm
You will have to pull the motor apart those weights are in there somewhere they are what caused all your problems and will continue to break stuff unless you get all the bits out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2017 at 10:02pm
Before you go to far, pull the valve cover and loosen all the rocker arms. This will let the valves close. Then roll the engine over with the crank and see if you have compression on each cyl. At least this way you could save pulling the head. All the rest goes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mikeks Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2017 at 2:36pm
Got the tractor up and running over the weekend. Clearly the governor weights have been an issue for a long time. Didn't realize how bad the throttle was until I got fixed. Governor weights were simple to replace, found a used camshaft gear, heated it up and it slid on with no issue. Pretty simple fix even with a lack of experience. Thanks again for all the great advise.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2017 at 3:38pm
Mike,
 I think your playing with us!:) Nice work doing the research and getting this tractor back together. Now drop some pictures on us!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2017 at 10:01pm
You need to look at the main page:
http://www.allischalmers.com/forum/default.asp
And then go to the bottom to:
Forum Support Only - No Tractor Questions
and then to:
Posting Pictures on the Forum
That should help you out....
We LOVE PICTURES!!!!
DonBC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonBC Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2017 at 4:15pm
Most engines, particularly older engines with gear or chain driven cams are not interference engines. I.E the pistons will not hit the valves so no damage can be done. Most new high speed, high compression overhead cam engines and belt driven cams are interference engines and major damage can occur if the timing belt breaks or even begins to slip. That is why it is important if your car has a belt driven cam that the belt is changed at or near the recommended intervals.
