D17 Exhaust Manifold Wanted
Smiling John View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Smiling John Quote  Post ReplyReply Direct Link To This Post Topic: D17 Exhaust Manifold Wanted
    Posted: 31 May 2010 at 1:09pm
I need an exhaust manifold for a gas D17 series III.  There is a large piece broken off where the muffler attaches.  Or could I weld on a piece of the proper size black or cast pipe to fix mine?
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2010 at 3:08pm
    we hasve a new manifold in stock [can ship]  with the pipe  visa   master cards
    1-800-254-3116
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2010 at 3:37pm
Neighbors cracked in same area , He said he was ordering a new one but if I could weld it up until that came , So I welded it with Allstate #8 cast rod. Asked him a year later if he had got new manifold , said no reason to his worked fine with weld repair .
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2010 at 6:36pm
I was going to buy one for my D17 series 4 as the top part was cracked off right where yours was.  I got a threaded pipe fitting and cut to size.   As I tried to weld it, the cast was falling apart as I tried to weld as it was really worn and pitted.  I ended up brazing it all together and it is holding together sofar.  I figured it will work long enough to get all the other things fixed and then as more money comes around, I will buy a new one when I need to.
This page was generated in 0.039 seconds.
