D17 engine seizes up when it warms up
djake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djake Quote  Post ReplyReply Direct Link To This Post Topic: D17 engine seizes up when it warms up
    Posted: 06 Aug 2025 at 7:26pm
My D 17 series 1 suddenly stops when engine gets up to running temp and the starter won’t be able to turn it over again. If I let the engine cool down good , it will start right up again. It will repeat the same problem if I let it run. It is never running hot, but at normal running temp. I had recently put in new pistons and liners, which I did with the engine in the tractor. Any ideas what might be going on?
ac45dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2025 at 8:09pm
piston to liner clearance too tight????
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2025 at 8:19pm
Piston pins not centered more likely.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2025 at 8:44pm
Did you get the rods turned right when you assembled the engine? Just had a WD45 reworked that I bought that was doing about you described,No 2 and 3 were wrong.
Docdan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Docdan Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2025 at 9:03pm
Are the rings gapped correctly? I had the same problem when I forgot to gap the rings in an earlier rebuild, I was 16 yrs old at the time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2025 at 11:10pm
Yah. If you don't put the rods in right and center the pins in the bore you will mess things up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2025 at 11:13pm
If you didn't clean the lower bores totally your sleeve may be getting squeezed when hot and be grabbing the piston.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2025 at 8:05pm
this is from the WD-WD45 manual............ but you get the idea...
This page was generated in 0.193 seconds.
