D-17 DISTRIBUTOR
Bigrigger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bigrigger Quote  Post ReplyReply Direct Link To This Post Topic: D-17 DISTRIBUTOR
    Posted: 25 Feb 2012 at 7:31pm
Need help finding a good distributor for a series I D-17 serial #17210. The shaft on my original is worn, and I can't seem to get the timing to stay right. Bought one off of Ebay to replace it, and as my luck would have it, same problem. Does anyone have, or know where to find a good one? Thanks.
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2012 at 8:01pm
  we have good used dist.  1-574-342-4545   can ship
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bigrigger Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2012 at 8:19pm
Thanks. Do you have a price and cost to ship to Ohio.
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2012 at 8:22pm
Do you need the shaft or the housing, what part is worn?
I have a housing that is usable, but the shafts and weights are wrong for a D17
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bigrigger Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2012 at 8:28pm
Shaft is worn.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2012 at 8:29pm
You'll have to call Norm, he typically doesn't put his prices up in public.  Probably not a bad policy.
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2012 at 8:39pm
I haven't heard it all, but I never heard of the shaft wearing to a point of causing timing problems.
 The shaft should run in replaceable bushings which do wear enough to let things slop around. This usually causes a variation in point gap which can cause spark problems.
Replace the bushings.
 Gears can have the pin sheared so it allows the timing to change. Replace the pin that keys the gear to the shaft.
