Print Page | Close Window
D-17 DISTRIBUTOR
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=46235
Printed Date: 05 Sep 2025 at 10:38am
Topic: D-17 DISTRIBUTOR
Posted By: Bigrigger
Subject: D-17 DISTRIBUTOR
Date Posted: 25 Feb 2012 at 7:31pm
Need help finding a good distributor for a series I D-17 serial #17210. The shaft on my original is worn, and I can't seem to get the timing to stay right. Bought one off of Ebay to replace it, and as my luck would have it, same problem. Does anyone have, or know where to find a good one? Thanks.
Posted By: norm[ind]
Date Posted: 25 Feb 2012 at 8:01pm
  we have good used dist.  1-574-342-4545   can ship
Date Posted: 25 Feb 2012 at 8:19pm
Thanks. Do you have a price and cost to ship to Ohio.
Posted By: Orange Blood
Date Posted: 25 Feb 2012 at 8:22pm
Do you need the shaft or the housing, what part is worn?
I have a housing that is usable, but the shafts and weights are wrong for a D17
Still in use:
Date Posted: 25 Feb 2012 at 8:28pm
Shaft is worn.
Date Posted: 25 Feb 2012 at 8:29pm
You'll have to call Norm, he typically doesn't put his prices up in public.  Probably not a bad policy.
Still in use:
Posted By: CTuckerNWIL
Date Posted: 25 Feb 2012 at 8:39pm
I haven't heard it all, but I never heard of the shaft wearing to a point of causing timing problems.
 The shaft should run in replaceable bushings which do wear enough to let things slop around. This usually causes a variation in point gap which can cause spark problems.
Replace the bushings.
 Gears can have the pin sheared so it allows the timing to change. Replace the pin that keys the gear to the shaft.
