D-17 Clutch
RadB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RadB Quote  Post ReplyReply Direct Link To This Post Topic: D-17 Clutch
    Posted: 04 Sep 2019 at 10:29am
I have a D-17 Series IV that we replaced the clutch in a few years ago. Everything was alright for a while, then the clutch started sticking and now you can not shift gears without shutting the tractor off. As you know, there is no adjustment for the clutch on a D-17. The tractor sits in a building that has a damp dirt floor. I suspect that the steel clutch plate has rusted. Do you have any suggestions other than break it apart again and replace the disc?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2019 at 12:25pm
Whenever I replace the clutch in an S4 or older 170/175, I always replace the clutch shaft and hollow shaft seals. While the hollow shaft is out, I remove the brass bushing inside of it to prevent it from dragging along the clutch shaft. It might not be your clutch, it could be the hollow shaft bushing.
