D-15 Series II LPG decal
Oldoug View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oldoug Quote  Post ReplyReply Direct Link To This Post Topic: D-15 Series II LPG decal
    Posted: 29 Jan 2010 at 7:02pm
I have a customer looking for a decal on his Series II D-15 LPG tractor.  It's a decal on the hood that says "LPG Series II" it's localed under the "ALLIS-CHALMERS" hood decal.  I can't find it on the parts card anywhere and AGCO has been no help so far.  If somebody has a old parts book with a part number that would be great.  Thanks for any help.
Wendell(OK/TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wendell(OK/TX) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2010 at 5:24am
Bumping this up as I have the same tractor and might need one someday!
MBwcIll View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MBwcIll Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2010 at 9:57am
I looked in our parts book, all I can see it lists is for Gas and Diesel transfers. The date code on our book is 3/66     Andy
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2010 at 10:09am
I looked through my D15 II parts manual, dated same as MB's and no luck.
I have seen the decal you are refering to on a D17 LPG, not sure what series, and I just don't have a D17 parts book.
dpower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dpower Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2010 at 12:37pm
We have that original series III D-17 propane with the series III propane sticker. If you want you could try to make a copy of that but change it to II.
MikeB (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MikeB (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2010 at 3:40pm
 I bet your looking for a needle in a haystack Doug. I can't even recall seeing a
D15 Series II propane. They only made 40 LP's in 1960 and most of those were
for the D14's. They made 51 LP's in 1961 and 31 LP's in 1962. Records were lost
for the Series II production but with high octane gas and a diesels becoming more
prevalent in the mid to late sixties, my guess would be less than 180 Series II propanes
build and probably about a little over 90 Series I's were ever made. Somebody should
start a serial number registry for the D15 propane models.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2010 at 7:03pm
D15IIP is a nice unit, starts instantly, plenty of power and quite the handy utility size with the power steering. Mine will easily outdo my D15II gas unit, but the gasser is tired.
Love those 160's and sized right for the tractor size/weight.
Now if I could only find that D15II gas unit with factory 3-point and A-C all hydraulic loader .......
This page was generated in 0.217 seconds.
