D15 series II hydraulic pump failure |
Post Reply |
1950AllisWD
Bronze Level Joined: 04 Jan 2025 Location: Iowa Points: 12 |
Posted: 04 Jan 2025 at 7:43pm |
I've got a 63 Allis D15 that the hydraulics have been weak on since I bought the tractor. It also pushes hydraulic oil from the hydraulic sump into the power director housing. I decided to drop the pump this winter to see what was going on. It would appear the pump had been run low causing damage to the cam lobes on the input shaft and causing total failure of one of the roller followers. The inside of the sump was full of steel shavings. I've got the pump mostly disassembled. The plungers and most of the internals don't look to be in bad shape. I'm looking for input on whether or not I should buy a used pump or if I'll be fine cleaning up the one I have. The tractor still had lifting power, it was just slow and would not lift all the way up in one go. I'm leaning towards replacing the input shaft with a good used unit as I have to tear the torque housing down to replace the seal between the hydraulic sump and power director anyhow. While the tractor is apart I plan on going through everything from the flywheel back. Power director seems to work fine, stays in as long as the oil level doesn't get too high. Tractor doesn't jump out of any gears. I was planning on replacing the hose and cylinder seal on the real lift cylinder while I'm in there. The tractor has a loud and I mean loud howl in 4th gear. Sounds like the final drives. I've heard that this is just how these tractors are but I've never been on another d series. Going to go through all the bearings in the trans and finals. Any thing else I should check out while I have it apart? Sorry for such a long post.
AC720Man
Orange Level Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 4998 |
Not sure how to describe the sound in 4th gear on our series II but it’s made it since it was new. I guess your description seams fitting. Don’t think you have an issue, it’s just how they are. Have 2 neighbors that theirs makes the same sound. How do your brakes function? Good time to check the seals and brakes.
Edited by AC720Man - 04 Jan 2025 at 7:57pm |
1950AllisWD
I plan on checking the brakes when I go through the final drives. Good to know the howl isn't anything to be too concerned about. I'll post some pictures as soon as I figure out how.
AC720Man
Change the oil in the bull gear pan. That is often over looked.
1950AllisWD
DiyDave
Orange Level Access Joined: 11 Sep 2009 Location: Gambrills, MD Points: 52096 |
1. clean off the burr on the cam, by whatever means you can. I have bumped the starter, with the plugs out, while an assistant held a strip of emery cloth against the cam. Cam does not look extremely bad.
2. while you have it down, r&r the internal cyl lift hose, in back, if it ain't bad, it will be soon...
Kenny L.
Orange Level Access Joined: 12 Sep 2009 Location: NEIOWA Points: 1283 |
Also a good time to replace the shaft (70228627) and bushing ( takes 2 70233270) that the clutch pedal rides on if there is a lot of play also the o-ring (70232984) for the pto shifter and both o-rings on the power director shift (takes 2 70232985). If you do the brakes and your tractor serial no. is 9001 & up, watch the washer spring they're 6 of them they're NLA. Also welcome to the forum. What part of Iowa your from? I use Bill Deppe for most of my use parts and after market parts he's located in Maquoketa, Ia 563-652-2949 shop 563-357-2615 cell and Helle Equipment in Dyersville Ia 563-875-7154. for new parts, or Gerry VandeVorde 319-350-6710 after market parts. HTH
Edited by Kenny L. - 05 Jan 2025 at 6:58am |
PaulB
Orange Level Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 4822 |
If needed: I have a complete used "take out" D14/15 pump available. $100 + shipping.
Orange Level Access Joined: 12 Sep 2009 Points: 20840 |
If it was mine, and I didn't need to use the lift arms for heavy lifting or a mounted plow requiring the Traction Booster system, I'd probably source a salvage yard hydraulic stack from a D-17 IV, 170 thru 185 and fabricate an under hood belt driven 5 to 6 GPM hydraulic pump. Or go with the hyd loader style crankshaft driven pump and just go without the high pressure system and changing out a clutch shaft, which is a big job. CoggonObrien has a post on this D-15 II live system from about 5 yrs ago. It may have been titled "D-015 series 3 hydraulics" or something like that.
Edited by DrAllis - 05 Jan 2025 at 8:12am |
1950AllisWD
I've got to replace the seal between the sump and power director anyway so I'll have the shaft out to deburr and inspect. We'll see what it looks like once it's out of the tractor. I definitely plan on replacing the rear lift cylinder hose while I'm in there. |
1950AllisWD
The pedals are actually pretty tight on this tractor. I'll definitely be replacing any seals/orings/gaskets I come across. I'm in north central iowa. Thanks for the good leads on parts sources. |
1950AllisWD
I may be interested eventually. I'll message you if I decide to completely replace the pump. |
1950AllisWD
I've seen that thread on adding live hydraulics and a d17 IV valve stack to a d15. I'd like to do that eventually to run along side the allis pump. I've got a snap coupler plow I pull at shows from time to time and I would like to keep the traction booster intact. |
If the oil transfer problem was on my D-15, I'd just knock out the plug between the compartments and let the oil run between them like a Series 3 D-17 was. Your clutch shaft looks terrible and if you want to keep the old pump system, the clutch shaft seals replacement is a no-brainer while replacing the clutch shaft. This failure didn't happen overnite. It was like that when you got the tractor. Unfortunately, there are many of these vintage tractors that do not use the hydraulics at all and the oil levels aren't maintained properly and who knows how low it might have been on oil. EDIT: and every D-15 I've ever driven down the road howl like he77 at road speed.
Edited by DrAllis - 05 Jan 2025 at 4:23pm |
SteveM C/IL
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8330 |
Dad was the local mechanic. Worked on anything that had an engine. Told me a lot of the old retired Allis's ruined hydraulic pumps and cams because nobody checked the oil anymore. Just as Doc stated.
1950AllisWD
I'm guessing it probably happened when grandpa owned it. Had no trouble lifting a 6ft brush hog when I was a kid. Made a little more progress this weekend. Splitting the transmission from the torque housing will be the next task.
Mikez
Orange Level Access Joined: 16 Jan 2013 Location: Usa Points: 8458 |
Probably your problem with tractor is is that John Deere clock on wall.
Haha just kidding
1950AllisWD
I've made some progress this weekend. I got the torque housing split from the transmission and got it up on the bench. Spent some time cleaning the hydraulic housing and bell housing out. Was finally able to get the clutch shaft pulled. The seals between the hydraulic sump and the power director were completely gone. The seals on the clutch end were not much better. The clutch shaft cams are real rough. Looks like we will be searching for a replacement. Also pulled the clutch and flywheel off the motor. Clutch disc still has quite a bit of life left in it. Throw out bearing feels good. All of the clutch fingers are worn unevenly. I'm assuming this can be corrected by adjusting them so they all contact the throwout bearing evenly? Ring gear teeth are rounded in a few places. I'm guessing the ring gear can be reversed? Figured I will probably flip it and rotate it a bit so the wear spots are not in the same place.
1950AllisWD
SteveM C/IL
Often only one side of ring gear is chamferd for bendix engagement. Just be aware.
If the ring gear isn't too bad, rotate it 90 degrees !!! Do NOT turn it over. Engines only stop in two places. Rotate it 90 degrees and you'll have new meat.
1950AllisWD
Yep, looking at the picture of it I believe it's only chamfered on one side. I'll just rotate it 90 degrees. Thanks!
Does anyone know if the clutch shaft is shared between the d14/d15 series I/II? Is the hydraulic pump assembly the same as well? Looks like Agco still stocks most of the seals and gaskets. |
Post Reply | |
