D-15 Series II front weights
coastga View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote coastga Quote  Post ReplyReply Direct Link To This Post Topic: D-15 Series II front weights
    Posted: 24 Jun 2010 at 11:32am
I have a 1965 D-15 series 2 (Gas) that I would like to put some front stack weights so that I can use a larger rotary mower. I currently have a 5ft rhino brand and do not need weights. However, I would like to purchase a larger mower. I have borrowed my neighbors 6ft mower but it often lifts up my front end.
Did Allis make brackets and weights for my D-15? What is the most affordable way to accomplish this task.
I restored my D-15 four years ago and made the mistake of using it on the farm. I wish I had keep it in mint restored condition. However, the D-15 is a nice work tractor. Rare machine in South Georgia.
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2010 at 12:19pm
They make front Wheel Pie weights if you can find them
Charlie
BrettPhillips View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2010 at 12:19pm
The D15 and D17 share the same frame width and front implement mounting points, so D17 stack weights fit right on a D15.  That's the easy part.  Now you get to find and pay for the weights and bracket...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2010 at 2:15pm
You can also get about 50lbs a tire in the front (assuming at least 6:00-16 tires) but filling them with fluid - I put -20 windsheild washer fluid in the front tires of my D17.  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2010 at 4:27pm
If your not concerned about originality, you could buy some suitcase weights and make a frame on the front to hang them on. That would be way cheaper.
Post Options Post Options   Thanks (0) Thanks(0)   Quote coastga Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2010 at 4:58pm
Does anybody have a picture of an orginal frame that the weights hang on? I would like to pattern my repo to the orginal if I have one machined. Any picture of the orginal weights?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2010 at 5:39pm
Here's the weights (first in the list) from Brian Ahart's weight page:
http://www.brianahart.net/weights.htm
Also look on his image archive for pics of tractors with the weight bracket:
http://www.brianahart.net/album/index.htm
Mike
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2010 at 7:49pm
  we have the front weight brackets  can ship    1-800-254-3116  visa --master cards
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2010 at 9:19pm
Wouldn't the front wheel weights for a WD/WD45 etc.  also fit on a D15's front rims?  I think those weigh close to 80 lbs. or more and would be easy to put on and not take up any extra room.   sometimes they are easier to come by then the stack weights and may/may not be expensive in your area.
