D15 series II Front Oil Seal Replacement |
Post Reply |
GregLawlerMinn
Orange Level Joined: 11 Sep 2009 Location: Lawler, Mn Points: 1226 |
Posted: 16 Jan 2020 at 12:04pm |
Has power steering. Front oil seal is dripping. Can I replace the seal without pulling the front support from the tractor?
Edited by GregLawlerMinn - 16 Jan 2020 at 12:26pm |
Currently have: 1 D14 and a D15S2. With new owners: 2Bs,9CAs,1WD,2 D12s,5D14s,3D15S2s, 2D17SIVs,D17D,1D19D;1 Unstyled WC |
PaulB
Orange Level Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 4419 |
It will be a lot easier in the long run if you pull the front support and oil pan off along with the timing cover if you only want to do it once.
If you can't make it GO... make it SHINY |
DSeries4
Orange Level Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7204 |
Did my D14 last winter. Best to pull the axle, you need a gear puller to pull the crank pulley off. You will also need to remove the oil pan to get the seal and timing cover centered properly. Going to be doing the neighbor's D15 in the next couple of weeks.
Post Reply | |
