D15 not charging
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: D15 not charging
    Posted: 25 Jul 2025 at 10:17pm
I have a D15 II that is not charging I think. It has the generator and voltage regulator setup. What do I check it, how do I check it. Thanks, Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2025 at 10:29pm
Ground the "F" wire on the Generator and see if it starts charging.
Momentarily touch "FLASH" the "A" wire on the Generator to the battery NEGATIVE terminal and see if it starts charging.. ( assume your are positive ground ?)
both of these tests to see if the REGULATOR is the problem..
You can also take a volt meter and put across the two generator terminals while running and see what the voltage is... to test the Generator..
Edited by steve(ill) - 25 Jul 2025 at 10:31pm
snowman(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowman(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2025 at 9:01am
Check to see if your brushes are freely moving inside the generator.  I believe you can do this without removing the generator.  Just an idea as I had a electric alternator/starter guy show me this.  Believe he used a small pick to try and move the brush.
1950 WD, 1966 D-10 III, 1961 D-10 II, 1966 D-15 II Gas, A-C Minibike, 917 Hydro Mower, 917 Hydro Blower w/cab, West Michigan "Allis Express"
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2025 at 9:05am
this guy shows how to test a generator.. I dont do the first "motor" test... I start a the 1:20 mark for what i described above...
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2025 at 10:58am
The first step in troubleshooting is to verify if it is indeed charging or not. What are the symptoms?
Does the ammeter show any movement at all in either direction with the tractor running?
With the engine revved up, try putting a voltmeter directly on the battery terminals (NOT on the cable connections). A 6 Volt system should show at least 6.8 Volts or more, 12 Volt system should be above 13.
Next, check the voltage right at the Armature terminal on the generator; if that voltage is low, then proceed with the steps outlined by Steve.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2025 at 11:00am
Remember, just because a Generator "motors" doesn't mean it'll charge. The best way to test the unit is take it to a rebuilder and have him load test the unit. If the unit load tests out okay, clean and check the ground on the Voltage Regulator. If it still isn't charging, remove the VR cover and give the contacts a spritz of Brakekleen or TV tuner cleaner and then try it. If the contacts are greenish probably time for retire the VR with a new unit.
Steve@B&B
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2025 at 7:27am
You can get a 1 wire alternator and alternator bracket made for a D15 for about $150 total off ebay  and end the charging drama.Put that set up on mine about 2 years ago love it.
This page was generated in 0.127 seconds.
