D15 II Power Steering
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Topic: D15 II Power Steering
    Posted: 01 Feb 2021 at 9:55am
Are the power steering hoses still available? I looked on agcoparts but couldn't find them.
Was looking at replacing these partial rubber hoses while we have it apart. 52 years figure they would be cracking up by now...
D15 series 2 (Late model)
Charlie
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2021 at 10:09am
Page # 286
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2021 at 10:15am
Watch the AGCO hoses I bought a PS hose from AGCO for my Oliver 1365 fittings were not right,one of the mechanics made me one up that worked perfect, plus I ended up about $50 to the good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2021 at 11:39am
Originally posted by Alvin M Alvin M wrote:
Page # 286
Those are similar but don't match entirely to what I have.
Charlie
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2021 at 11:43am
There is only one hose on the PS. It is the return hose. The rest are tubes from the factory.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2021 at 11:44am
These are what I am looking for
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2021 at 12:12pm
Charlie: Send them to  Inline tube  They can match them exactly as the originals, with the hose parts and the tube parts with all the correct bends.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2021 at 1:23pm
Thanks Paul!
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomstractorsandtoys Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2021 at 5:37pm
When you get what you need post back with the price as my series II should have a set as well. Tom
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2021 at 8:42pm
Here is what I have done.  I took all the lines to my local hydraulic shop.  They made new flexible sections the same size and provided me with compression fittings.  I cut out the old flexible pieces, put the new ones in place and tighten down the fittings.  Pretty cheap too.  How do these look?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2021 at 6:51am
That works! Might have to try that
Charlie
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2021 at 8:00am
Been using those compression fitting for years u just need a good round steel line to install them .
nonetheless ,still dead.
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2021 at 9:30am
I have the D15 II lines ready-made and on the shelf if you want to go that route.
www.awtractor.com
A&W TRACTOR 920-598-1287
