D15 II Power Steering |
Charlie175 ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6359 |
![]() ![]() ![]() ![]() ![]() Posted: 01 Feb 2021 at 9:55am |
Are the power steering hoses still available? I looked on agcoparts but couldn't find them.
Was looking at replacing these partial rubber hoses while we have it apart. 52 years figure they would be cracking up by now... D15 series 2 (Late model)
Charlie
Alvin M ![]() Orange Level ![]() Joined: 24 Jun 2018 Location: PA Points: 790 |
Page # 286
Gary Burnett ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Virginia Points: 2986 |
Watch the AGCO hoses I bought a PS hose from AGCO for my Oliver 1365 fittings were not right,one of the mechanics made me one up that worked perfect, plus I ended up about $50 to the good.
Those are similar but don't match entirely to what I have.
Charlie
Joe(TX) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Weatherford. TX Points: 1682 |
There is only one hose on the PS. It is the return hose. The rest are tubes from the factory.
These are what I am looking for
Charlie
PaulB ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 4903 |
Charlie: Send them to Inline tube They can match them exactly as the originals, with the hose parts and the tube parts with all the correct bends.
Thanks Paul!
Charlie
tomstractorsandtoys ![]() Orange Level Access ![]() Joined: 11 Feb 2015 Location: wi Points: 515 |
When you get what you need post back with the price as my series II should have a set as well. Tom
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7421 |
Here is what I have done. I took all the lines to my local hydraulic
shop. They made new flexible sections the same size and provided me
with compression fittings. I cut out the old flexible pieces, put the
new ones in place and tighten down the fittings. Pretty cheap too. How do these look? ![]() |
That works! Might have to try that
Charlie
Fred in Pa ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: Hanover Pa. Points: 9210 |
Been using those compression fitting for years u just need a good round steel line to install them .
nonetheless ,still dead. If all else fails ,Read all that is PRINTED. |
Alex09(WI) ![]() Orange Level ![]() ![]() Joined: 15 Mar 2012 Location: CECIL WI Points: 1717 |
I have the D15 II lines ready-made and on the shelf if you want to go that route. ![]() |
www.awtractor.com
A&W TRACTOR 920-598-1287 KEEPING ALLIS-CHALMERS IN THE FIELDS THROUGH THE 21ST CENTURY |
