D-15 II engine needed
tonysac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tonysac Quote  Post ReplyReply Direct Link To This Post Topic: D-15 II engine needed
    Posted: 26 Jan 2010 at 12:40pm
Hello, I'm looking for an engine ,running or not ,if diesel ,then i need complete or if gas ,partial engine??  thank you
Tom IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom IL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2010 at 4:53pm
I needed a gas one a few years ago, found Series II are a little hard to find and pricey when you do.
MikeB (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MikeB (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2010 at 6:01pm
 What happens to them that you need to find a whole new engine? They are quite rare up here. I'm can't remember a one at the Gathering of the Orange at Madison SD this past summer. I know there are a lot of guys trying to find this engine to bolt in their CA pulling tractors. Since they didn't make very many of engines they are going to be expensive. What's to stop a guy from obtaining the more common D14 and early D15 G149 engine and installing the larger bore G160 piston and sleeve kit? I know the crankshaft is the same. You could use the governor spring and intake and carb off of your old engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tonysac Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2010 at 6:18pm
Well the engine is in a I 600 and its pretty well shot,but if the smaller engine would fit ,i would be for that also,i don't care really about power ,i am sure the smaller engine would have enough power to dig .i have a skidloader to do all the pushing.so it will only be used for digging with the back end,how would i know if it would fit??  thank you
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2010 at 6:26pm
The G-160 block is bored bigger to accept the larger diameter sleeves.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tonysac Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2010 at 6:28pm
so its the same block?? that means it will bolt right in??
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2010 at 7:05pm
  we have a 149 engine   what is needed  1-800-254-3116   location???
BrettPhillips View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2010 at 7:54pm
The 160 CID block is grooved for the sleeve O-rings, while the 125, 138 and 149 engines have the O-ring grooves on the sleeves.  Connecting rods are different too...
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2010 at 8:56pm
149 engine has the grooves in the block also. Sleeve is too thin. Bob
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2010 at 7:04am
What are the problems with your current engine?
Edited by JoeO(CMO) - 27 Jan 2010 at 7:06am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2010 at 7:12am
Series II motor is also 2" or there abouts, wider than the earlier motor. (at the frame rails)
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2010 at 7:29am
Both D-15 (series 1 and series 2) are wider (about 2 inches) at the timing cover mounting plate. D10-12-14's are narrower.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2010 at 7:59am
Ok, I stand corrected.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tonysac Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2010 at 11:09am
well my deck is cracked and the sleeves and pistons are shot ,one rod bent too much to straighten,just plain abused and worn out......
