D-15 II engine needed |
tonysac
Topic: D-15 II engine neededPosted: 26 Jan 2010 at 12:40pm |
Hello, I'm looking for an engine ,running or not ,if diesel ,then i need complete or if gas ,partial engine?? thank you
Tom IL
Joined: 11 Sep 2009 Location: Marshall, Il. Points: 26 |
Posted: 26 Jan 2010 at 4:53pm |
I needed a gas one a few years ago, found Series II are a little hard to find and pricey when you do.
MikeB (SD)
Joined: 13 Sep 2009 Location: NE South Dakota Points: 80 |
Posted: 26 Jan 2010 at 6:01pm |
What happens to them that you need to find a whole new engine? They are quite rare up here. I'm can't remember a one at the Gathering of the Orange at Madison SD this past summer. I know there are a lot of guys trying to find this engine to bolt in their CA pulling tractors. Since they didn't make very many of engines they are going to be expensive. What's to stop a guy from obtaining the more common D14 and early D15 G149 engine and installing the larger bore G160 piston and sleeve kit? I know the crankshaft is the same. You could use the governor spring and intake and carb off of your old engine. |
tonysac
Posted: 26 Jan 2010 at 6:18pm |
Well the engine is in a I 600 and its pretty well shot,but if the smaller engine would fit ,i would be for that also,i don't care really about power ,i am sure the smaller engine would have enough power to dig .i have a skidloader to do all the pushing.so it will only be used for digging with the back end,how would i know if it would fit?? thank you
Posted: 26 Jan 2010 at 6:26pm |
The G-160 block is bored bigger to accept the larger diameter sleeves.
tonysac
Posted: 26 Jan 2010 at 6:28pm |
so its the same block?? that means it will bolt right in??
norm [ind]
Joined: 16 Sep 2009 Location: BOURBON,IN. Points: 667 |
Posted: 26 Jan 2010 at 7:05pm |
we have a 149 engine what is needed 1-800-254-3116 location???
BrettPhillips
Joined: 11 Sep 2009 Location: Strasburg, VA Points: 808 |
Posted: 26 Jan 2010 at 7:54pm |
The 160 CID block is grooved for the sleeve O-rings, while the 125, 138 and 149 engines have the O-ring grooves on the sleeves. Connecting rods are different too...
Chalmersbob
Joined: 11 Sep 2009 Location: Pennsylvania Points: 2122 |
Posted: 26 Jan 2010 at 8:56pm |
149 engine has the grooves in the block also. Sleeve is too thin. Bob
JoeO(CMO)
Joined: 11 Sep 2009 Location: Cent Missouri Points: 2696 |
Posted: 27 Jan 2010 at 7:04am |
What are the problems with your current engine? Edited by JoeO(CMO) - 27 Jan 2010 at 7:06am |
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54756 |
Posted: 27 Jan 2010 at 7:12am |
Series II motor is also 2" or there abouts, wider than the earlier motor. (at the frame rails)
Posted: 27 Jan 2010 at 7:29am |
Both D-15 (series 1 and series 2) are wider (about 2 inches) at the timing cover mounting plate. D10-12-14's are narrower.
DiyDave
Posted: 27 Jan 2010 at 7:59am |
Ok, I stand corrected.
tonysac
Posted: 27 Jan 2010 at 11:09am |
well my deck is cracked and the sleeves and pistons are shot ,one rod bent too much to straighten,just plain abused and worn out......
