D15 governor response |
cowkicker
Topic: D15 governor responsePosted: 16 Nov 2016 at 7:32pm |
Recently replaced a failed governor on my D15 with a used one. Now the tractor is really dead when it is time for the governor to kick in. I did use the original spring when doing the repair. Any suggestions on what I did wrong or what to do to get it back to normal. Tractor has always had a very responsive governor til now. Thanks!
Tracy Martin TN
Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10869 |
Posted: 16 Nov 2016 at 8:00pm |
Do you have a service manual? Tracy
cowkicker
Posted: 16 Nov 2016 at 9:25pm |
Yep, I got one, didn't think about looking there. Do you recall if it says anything about any type of adjustment? |
Albert
Posted: 16 Nov 2016 at 9:42pm |
check your timing would be my first thought.
Posted: 16 Nov 2016 at 10:35pm |
Assuming you have the ignition timing set with a timing light at 25 degrees BTDC at wide open throttle, we'll go from there. Engine off. Hand throttle wide open. Remove the cotter key from the governor arm link rod above the generator. The length of the carburetor link rod should be such that it just drops down out of the governor arm hole and can be easily reinserted. If it is too short (I think it is) remove the link rod from the engine and straighten out some of the bends to make it longer. 1/8" too long can make a difference. Do this adjustment FIRST and then see what you have.
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5191 |
Posted: 17 Nov 2016 at 6:01am |
On the small engines the cross rod from the governor needs bending so that the carburetor rod is just a tiny bit too short. Your service manual explains this in detail.
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54679 |
Posted: 17 Nov 2016 at 5:48pm |
Yep, bow it in or bow it out, till it acts right...
mruhlig77
Joined: 19 Aug 2014 Location: central Indiana Points: 595 |
Posted: 19 Nov 2016 at 7:33am |
I had the vertical rod rust up on one..be sure all the actual linkage is free...or the wrong parts will or will not adjust..Mark then do the bend thing..
