D-15 Engine
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Topic: D-15 Engine
    Posted: 31 Jan 2018 at 3:14pm
Checked the compression on my non-running D-15 today . First 3 cylinders were 60-70 max , last one was 160 . Bought this tractor with the oil pan and starter pulled off . Seller said the motor was locked up . Any advice ? It's a Series one . Serial #D15 2595 .              THANKS !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2018 at 4:20pm
Forgot to say this is a gas D 15
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2018 at 4:44pm
60 to 70 is real low.  Rebuild it.  Kits for the 149 are readily available for a decent price.
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2018 at 8:37pm
probably needs a rebuild, you could look in the spark plug holes at the cylinder walls before you take it down, if you know some one with a scope camera or shine a flash light down there,but that doesn't work as well.
could just need some valve work.
just some more things to think about.
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2018 at 9:36pm
Check head gasket first. Advanced timing will get head gasket on them motors.    MACK
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2018 at 9:51pm
Is it possible valve aren't shutting on the three cylinders with low compression or if it has been sitting put some oil in the cylinders to help compression.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2018 at 10:18pm
Yep, I'd do a wet compression test first. If numbers don't go up, you've got valve issues.
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2018 at 4:52am
Could be the rings are stuck. If you can get something in there that will loosen them up also, would be a help.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2018 at 5:27am
I'd try to get it running for awhile and see how it runs,if it smokes etc.The rings might just be stuck a little and running will usually break them loose plus by running it you'll find out things like whats the oil pressure and such.Tearing into the motor is the last thing to do not the first.
dt1050 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2018 at 5:47am
I used some diesle fuel and pb blaster mix to get my d17 unstuck.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2018 at 6:59am
I would do a leak down test
nonetheless ,still dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2018 at 7:37am
THANKS for all the replies . Should've also said that none of the cylinders will hold any pressure . I'll squirt some oil in each cylinder and re-test .
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2018 at 7:52am
New pistons and sleeves and grind the valves and seats. You can test all you want but you are going to tear it down for an overhaul.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2018 at 8:07am
Not sure what to do . I'd hate to sink $2,000 in a engine rebuild only to discover the drive train is junk . All I know for sure is that the brakes work .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2018 at 8:17am
Exactly why I'd try to get it running no matter how bad it runs at least you can check out
everything else to see if its worth working on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2018 at 7:38am
I like your thinking Gary . One of the ignition wires is broken so I may replace all the wires , plugs , cap , etc . THANKS !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2018 at 2:03pm
Hard to believe , but my son and I got this D 15 running today . I drove it around the yard a few minutes and it quit . Got it back in the shop and got the motor started again . It will run a couple minutes and quit . If it sits 5 mins it'll start and run again for a couple mins . Gonna pull the fuel line and see if I can figure out what's going on . We have gas at the carb but it's sure not a strong stream . Should say I replaced the plugs , wires , cap , rotor , points and cond . THANKS B and B . Any advice is welcome .
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2018 at 2:05pm
is it vapor locking? try running it with out the gas cap on. could also be a coil, next time it shuts off check for spark.
Edited by dt1050 - 11 Feb 2018 at 2:07pm
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2018 at 3:22pm
It sounds (to me) to be a fuel problem. Sounds like it burns the fuel out of the carb bowl, then quits. Have you tried removing the sediment bowl and cleaning the passages out?
Personally, I would make sure to have really good fuel flow before spending money on other parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2018 at 3:43pm
Yep, I had that same problem with a tractor once...start and run for a couple minutes, then quit. Start again, same thing. Got it limped back to the house, blew the line out, and that fixed the problem until I had time to clean the tank.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2018 at 4:24pm
bet we've all been there...
tear sediment bowl of tank, flush tank out REAL good. I fill with water ,let it 'pee' out 2-3 times then use compressed air to blow dry, swish  winter squirter fluid in(have lots) ,drain then clean sediment bowl and line with carb cleaner. Put 2-3 gallons of FRESH gas in ,see how it pours out at carb connection. It should be see through clean. NOW connect to carb and try again.
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2018 at 2:15pm
Put a new sediment bowl I had on today . Old one was gunked up . Now the fuel line won't line up to the new bowl . NAPA has some bendable polymor/ steel brake/fuel lines . Anyone used them ? I'm not thinking a rubber hose would be safe solution ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2018 at 2:30pm
Personally I'd never use rubber. I've always used copper or steel. Rubber just sounds risky to me. Plus, I think it looks much cleaner with a properly routed copper or steel line.
Edited by CrestonM - 12 Feb 2018 at 2:31pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2018 at 3:09pm
hmm I've always been able to 'tweak' the steel line on my D-14s..so I'm thinking you should be able to. Be sure to quite brake cleaner  through it though, its probably gummed up to. Heck, maybe a new line(metal), $10-$15 ?, cheap investment .
jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2018 at 3:21pm
D-15's had a rubber fuel line from the factory on series 2's.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2018 at 4:08pm
I just checked....both S1 and S2 had the rubber fuel line from factory.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2018 at 1:47pm
Tweaked my sediment bowl and the metal fuel line this morn . Took a while but I finally got everything lined up and put together . Tractor fired up and ran until I turned the key off . One problem solved , I'm sure I'll be back soon with another . THANKS !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2018 at 1:59pm
NICE I like to hear someone's having a good day !!
I slid on some shiny, slippery,ICY Shamless 'donation' today, yanked my arm( right  of course) and now it's hurting..along with elbow and wrist.  Sure glad there's 35days until Spring ...maybe I'll heal by then ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2018 at 8:09pm
How did it run? Smoke? I’m sure everyone knows about Seafoam. I highly suggest it. Put it in the fuel and in the crank case. It does an excellent job of cleaning fuel systems, valves, and stuck rings. You wont believe the color of the oil when you drain it. Black as can be. Run it at least 15 minutes or longer. Change oil and add more Seafoam. Depending on the severity of grim it may take several changes to clean the gunk out.
I had an engine that blew blue smoke so bad I couldn’t see the front of my shop when I finally got it running. 3 oil/filter changes later, 1 hr run time total she was and is still smoke free to this day. Compression went from 82 psi to over 135. 2 cylinder Onan. I highly recommend the product. Use it regularly in my fuel tanks, keeps O2 sensors clean as well as injectors or carbs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2018 at 1:48pm
It runs pretty well for a "locked up" motor . Hafta run it with the choke partly closed . I'm sure the carb needs attention . Soon as I get a lip put on what's left of the battery tray I'm gonna run it thru all the gears . It doesn't smoke much at all . Always heard sea foam was good stuff . THANKS !!
