D-15 Engine Swap Diesel to Gas |
D-17_Dave ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Mocksville NC Points: 990 |
![]() ![]() ![]() ![]() ![]() Posted: 31 Aug 2011 at 5:02pm |
What are all if any differences are there? I have an Industrial Diesel with an engine that will need a lot of work and I have access to a 149 CI power unit. With me being out of work right now I'm looking at how to get the tractor up and running sooner rather than later.
Will the engines bolt up? Is there a difference in the flywheel's or torque tube input shafts like a D-17. Or anything else I should be aware of before digging deeper. it's not pretty much a direct bolt up then I'll likely wait for a diesel engine. |
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21907 |
I'm not going to spend the time toi look up all the parts, but I'm pretty sure all these are different......radiator...starter......air cleaner.....throttle linkage.....flywheel......possibly the pressure plate........power steering pump and all the lines....radiator fan.....
Ryan Renko ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Edwardsville, I Points: 2336 |
I agree with the good Dr Allis. Its seems like not good idea to do that. To many issues. Ryan
Matt (Jordan,MN) ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Jordan, MN Points: 3802 |
I was told by a AC parts man that the clutch shaft in the torque tube is different. Matt Edited by Matt (Jordan,MN) - 31 Aug 2011 at 11:40pm |
