D14 split
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Topic: D14 split
    Posted: 22 Oct 2024 at 12:30pm
After running my new to me D14 for a few hours it looks like I’m going to have to do a split at the transmission to replace both seals on each side of the PD shaft where it exits the transmission. This is disappointing since the only leak when I tested the tractor was a known pinion or axle seal. It took several hours of running for this to show up. I’m sure this is due to the tractor sitting in the barn for 2 years and not ran. Will be a first for me at the trans of a D series other than pinion and axle seals. Will be researching the manual on the procedure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2024 at 12:45pm
I have been told you can do it from outside on a D17. Never tried myself though.
pirlbeck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pirlbeck Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2024 at 12:56pm
The PD operating cross shaft can be removed without splitting the tractor. The cross shaft has an o-ring groove towards each end.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2024 at 2:33pm
You do not have to split the tractor to replace the seals on the power director shaft (the one that the big stick is connected to).  Very easy job.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2024 at 9:14pm
Really? That’s great news. Just looking at it appeared I would have to spit it? Hope the procedure is in a manual.
Edited by AC720Man - 22 Oct 2024 at 9:16pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2024 at 10:26pm
Remove the setscrew from the big stick. Operate the big stick back and forth until it breaks loose from the shaft. Reinstall the setscrew loosely and pull back fully into low range. Remove the clutch cover on the right side. Reach inside the hand clutch area and remove the setscrew from the fork. Operate the big stick back and forth until the fork is free from the shaft. Remove the snap ring and washer from the left side. Remove the big stick and washers. Move the shaft sideways right and left and change out both Orings one at a time. Oil the new Orings so they slide together. Reassemble.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2024 at 11:17pm
Thanks Dr Allis! Your description is better than any manual. So glad I don’t have to split it. Will get the o-rings ordered tomorrow.
Thanks to everyone who also replied.
Edited by AC720Man - 22 Oct 2024 at 11:21pm
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2024 at 1:34pm
     You would of found this out if you started the job , shaft has to be remove to split tractor at P D and trans
nonetheless ,still dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2024 at 7:01pm
Ordered the o-rings today, should have these 2 leaks repaired this weekend. I will give a follow up when I get it repaired. I did remove the set screw and loosened the PD stick, so its ready to be removed.
