D14 SEAT ASSEMBLY |
HVFDFIREFIGHTER
Joined: 11 Jun 2013 Location: Heuvelton, NY Points: 563 |
Topic: D14 SEAT ASSEMBLYPosted: 12 Mar 2017 at 2:19pm |
So I took the D14 seat apart last fall. Finally got around to cleaning it up a little today. (Its only -4F out and we are now expecting a foot of snow). I thought I took pictures of the seat before I tore it apart. I either didn't take the pictures or I can't find them.
Does anyone have some pictures of the seat assembly? Pictured below is what I currently have. I will be sandblasting and painting before final assembly but I want to see if I can get it back together now. Also need to find some 1/2" rods and bushings as I had to cut most of the old ones to get them apart. Shock seems to be in good shape. Shock assembly (shock, spring, top and bottom cap) is not pictured because I have already cleaned them up, primed them and have them hanging in the warm shop. As always, any help would be appreciated.
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24901 |
Posted: 12 Mar 2017 at 2:36pm |
hmm..sounds like you're going to get the same snow as me...thanks to Shameless !!
Best 'help' I can give you , is you can 'practice' on 2 or 3 of my D-14s ! hehe...by the time you get mine done, you'll be an expert and do yours in 1/2 the time. I'm just west of Hamilton,Ont. Jay |
HVFDFIREFIGHTER
Posted: 12 Mar 2017 at 9:18pm |
Anyone have a photo of there d14 seat assembly?
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7574 |
Posted: 12 Mar 2017 at 9:54pm |
john(MI)
Posted: 12 Mar 2017 at 10:22pm |
![]() ![]() ![]() Looks like you are missing the narrow part in the picture above. I got all of the parts from DJS Tractor Parts. He is listed in the parts section on this site. Edited by john(MI) - 12 Mar 2017 at 10:27pm |
Steve79
Joined: 07 Jan 2011 Location: Edgerton KS Points: 224 |
Posted: 13 Mar 2017 at 9:21am |
Let me know If more pics are needed I can take some of mine tonight.
In your restoration did you replace the shock? mine may as well be a steel rod, I can jump on the seat and the spring/shock doesn't compress more than 1/4" |
HVFDFIREFIGHTER
Posted: 13 Mar 2017 at 9:22am |
Thank you for the picture of the D14 seat assembly
HVFDFIREFIGHTER
Posted: 13 Mar 2017 at 9:23am |
I did not replace the shock, it seems to have good compression
Posted: 13 Mar 2017 at 9:41am |
The spring carries your body weight. The shock keeps you from bouncing up and down like a jack-in-the-box. The shock carries zero weight.
john(MI)
Posted: 13 Mar 2017 at 3:53pm |
I replaced the shock and all of the bushings and rods. Was near 200 for it all.
HVFDFIREFIGHTER
Posted: 14 Mar 2017 at 1:49pm |
Thanks to the photos above, I was finally able to get my seat assembled. What a pain in the ***. Had to heat all areas to get the remains of the rods I cut to come out. Now that I know how it goes back together, I can start restoring it.
Here are some photos for anyone else with the same problem
The seat pan has a crack. I will try to weld or braze that later. Had the day off today! NO SCHOOL! Winter storm hitting hard! |
Dave H
Joined: 11 Sep 2009 Location: Central IL Points: 3595 |
Posted: 14 Mar 2017 at 4:34pm |
HV i had the same issue with my D 15 seat.
I had to go out the the plumbers house and take pitchures (as Less Says) of his and then mine fell right together. ![]() |
Dan73
Joined: 04 Jun 2015 Location: United States Points: 6054 |
Posted: 14 Mar 2017 at 7:26pm |
My d17 seat has some cracks I haven't tried to repair it yet. I need to do something I guess before it gets worse.
