D14 rear wheel |
Post Reply |
Killerkukoo
Bronze Level Joined: 02 Feb 2010 Points: 18 |
Posted: 05 Jun 2010 at 11:47pm |
Hi all. I have a friend who needs a D14 rear wheel. does anyone know where one is at? Also i have a wd 45 on wich the hydralic lever slowly moves up causing the loader to rise. the higher rpm's the faster the lever goes. Any ideas on how to fix this? I have only had my tractor for a couple months.
thanks for any info Jacob
Fred in Pa
Orange Level Joined: 13 Sep 2009 Location: Hanover Pa. Points: 9210 |
How wide is the rim he has ?, |
CTuckerNWIL
Orange Level Joined: 11 Sep 2009 Location: NW Illinois Points: 22823 |
Killer, there is a friction block on the lever that is supposed to help hold it in place. It might need to be replaced. If your traction boost isn't set right, the loader will raise up if there is pull on the drawbar. You should have a manual to show how this is set properly.
norm [ind]
Orange Level Joined: 16 Sep 2009 Location: BOURBON,IN. Points: 667 |
you did not say what type wheel needed [spin out or combine size]
Killerkukoo
He told me it is a spin out 28" wheel. the old one is rotted out from calcium to the point the tire cant even stay on. Im getting his info 3rd hand, as i found out its for a friend of a friend..
to CTucker ill replace those blocks first, thats easy and cheap enough, hopes that does it. i dont believe the traction booster is even functional, the lever is disconected. but i havent pulled anyting with it yet. its mostly a snow mover and chopper runner. thanks for the info. Jacob
Fred in Pa
When asking for a D-14 wheel ,they came with 26 inch rears.Sounds like someone went the cheaper way at one time and put WD rear hubs and rim's on it witch are 28's.
There is also a spring that pulls the lever against the block.
norm [ind]
we can furnish either 26"[0riginal] 0r 28' need width for matching correctly
1-800-254-3116
Post Reply | |
