D14 Rear Rims
rjranch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rjranch Quote  Post ReplyReply Direct Link To This Post Topic: D14 Rear Rims
    Posted: 19 Jan 2023 at 2:05pm
Looking for suggestions to what combine rim will work on a D14. I do not need to spin out for the tractors uses and would like to go with a 28" rim since used tires in 28" are easier to find. Anyone have a suggestion?
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2023 at 2:17pm
26" Rims are more common than 28s, but they use a bigger tire.  Keep in mind, combine rims stick out wider than the power adjust rims.  They will not sit close to the fender.
These are 18.4 x 26 combine rims on my D17:
Same tractor with power adjust rims:
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2023 at 3:42pm
probably any that are 26" with 8by8 bolt pattern.....
I've got a mix of spinout(power adjust) and combine on my 3 D-14s.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2023 at 3:44pm
as Myron said, most combines are 26 inch and WIDE...
What you want is a 28 inch rim about 12 inches wide with an 8 bolt pattern ???
your probably talking about something like this, with an adaptor plate to 8 bolt axle
Edited by steve(ill) - 19 Jan 2023 at 3:51pm
tractorboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorboy Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2023 at 6:28pm
I once owned a 14 that someone had changed rear rims , can't remember what size but they were taller than original .  I didn't like them cause they changed the gear ratio, seemed a little short on power but I could walk away from 'em on the tractor rides !!LOL
  keith so. va.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2023 at 9:01pm
i think original tires on the D14 were  12 x 26 ........... if you get combine tires they would be 14.9 or 16.9 x 26 ... so taller ........... if you go to a 28 inch rim, i would stick with 12.4 tires to keep the height within a couple inches of original.
Edited by steve(ill) - 20 Jan 2023 at 8:15am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2023 at 1:19am
For a combine 16.9 x 26 and 18.4 x 26 would be most common.
I have 3 D14s. None of them have 12.4 x 26. Those would be tiny in my opinion. 13.6 x 26 seems pretty common on a 14. I am running 14.9 x 26 on all of mine.
