D14 POWER STEERING FLUID
tomwestky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomwestky Quote  Post ReplyReply Direct Link To This Post Topic: D14 POWER STEERING FLUID
    Posted: 08 Dec 2010 at 2:30pm
My manual doesn't address it.  What is the appropriate oil/fluid to use in a D14 with factory power steering.
Thanks.
Tom Westerfield
Crofton, KY
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2010 at 2:48pm
It was ATF, dont remember if it was type a or type f.    Drain it out and use universal trans/hydralic oil now.     They used ATF cause it was lighter weight than the 20/20 used in the hydralic systems of the day.  ATF is about a 10w,  universal hyd is about a 10/20 weight. HTH
Edited by skipwelte - 08 Dec 2010 at 2:51pm
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2010 at 9:04pm
I use AFT in mine with no problems.  If anything, it works better in cold weather.
This page was generated in 0.053 seconds.
