D14 Power Director fluid level check
jtheise4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jtheise4 Quote  Post ReplyReply Direct Link To This Post Topic: D14 Power Director fluid level check
    Posted: 12 May 2011 at 8:13am
On the D14, the power director dip stick is a bolt.  What is the proper way to check the fluid level?  Should I be screwing the bolt into the seated position or checking the fluid level with the bolt threads just touching the housing?  Thanks.
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2011 at 10:05pm
threaded all the way in. When you  remove the bolt (plug) you can read the level on the dip stick. Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote jtheise4 Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2011 at 6:52am
Thanks.  I guessed correctly then.
1958 D14
This page was generated in 0.215 seconds.
