d-14 no start
tractorboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorboy Quote  Post ReplyReply Direct Link To This Post Topic: d-14 no start
    Posted: 12 Jan 2021 at 4:55pm
Went to start my d-14 been sitting bout a month and a half. Barely started then ran poorly, let run for 20 min. thinking it might clear up -no luck. Thinking it was a gas problem I drained tank and cleaned carb, no luck . Since the coil looked old as me [63], I took a newer coil off a running ca.  I've got juice to ign. side of coil but nowhere else, points were replaced last summer. What do I check next Thanks in advance, Yes I am a parts changer guilty as charged!!!!Angry  keith so va
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2021 at 5:07pm
I'd try a new condenser next.I just went thru a similar thing with my Oliver 66 tried about everything I could think of after digging into it turned out to be the intake part of the manifold had warped and wouldn't set exactly flush against the head.Good used manifold off ebay back in action.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorboy Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2021 at 5:09pm
Forgot to mention pos. ground , I hooked up the coil like my 17 pos. ground  it's 12 volt
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2021 at 6:53am
Points can/will oxidize while setting.  Try folding a dollar bill up and rubbing between the contacts to clean them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2021 at 7:28am
Dang what's a dollar bill ??? Up here I'd have to use a 'fiver' ! $1 and 2$ are coins, sigh.
 agree though, LIGHTLY clean the points, I use 1,000 grit paper( have lots....). matchbook works good...hmm, do THOSE still exist ???
Jay
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2021 at 6:24pm
You can use copy paper the clean the points.
Did you take off the sediment bowl and clean it?  Did you take the breather hose off of the carb and give it a shot of ether and try it?  Check the air cleaner for a mouse house.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2021 at 6:01am
Replace the points with Napa points and condenser ,or Blue streak . Any others are junk .Then start checking for other problems .
nonetheless ,still dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorboy Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2021 at 4:09am
If you put power to the ign. side of the coil , shouldn't the other side have power ????   Thanks, keith
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2021 at 5:51am
yes, but ONLY when the points are open...
you have to rotate the engine a bit to turn the  dist shaft to get the point an a 'lobe',which 'opens' the points.
 with tractor in neutral, you give a quick 'start' with the key. more often than not, the points magically go to 'close' not to 'open',but eventually you'll get them 'open'. otherway is to use a big,flat screwdriver in the bellhousing hole to turn the engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorboy Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2021 at 11:24am
Thanks Jay, after removing the points I think something was touching where it wasn't supposed to. I checked it with a test light, made a little bend in it ,rechecked it with light & started right up!!  Everyone says Blue Streak ign. but every Napa I go to has only Echilin on the box & looks cheap!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2021 at 12:25pm
BWD, Niehoff and Echlin are all Standard Motor Products companies.  SMP is the parent company of Standard/Blue Streak.  You just need to check the grade.  I don't know about the others but Standard, at least, is marketing many products in a "trade version" to be price competitive.  Here is how they say it: "Standard T-Series is a competitively priced line containing some of the most popular part numbers to help you meet your market needs. The Standard T-Series is a fit whenever a commercially acceptable product is called for."  Most of these parts use the same part number as the premium ones with a "T" added as a suffix at the end.  I stay with the premium Standard Blue Streak or Echlin.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2021 at 2:21pm
You can't tell by looks if a condenser is junk  you have to test them .
