D14 Lift Latches
Dave Richards (WV) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Richards (WV) Quote  Post ReplyReply Direct Link To This Post Topic: D14 Lift Latches
    Posted: 07 Mar 2011 at 3:19pm
When I got my D14, the lift latches were installed with the bolt in the hole on the end of the lift arm.  They held, but wobbled all around.  I recently loosened the bolt, pushed them all the way on, and tightened the bolt against the arm.  Fits much better now, BUT now they hit the fenders when all the way up.   "Wud" I do wrong?
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2011 at 3:38pm
   Does the latch hit or the bolt ?
http://www.rumelyallis.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Richards (WV) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2011 at 10:46am
The latch hits, I already moved the bolts to the inside.  The spring rivets can be pounded in some, but still not enough clearance.  I will be checking to see if the fender brackets are on the wrong side of the fender.  The 14 uses the same latches as the  17, don't they?
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2011 at 7:52pm
Maybe the lift arms had been take off the rockshaft at one time and reinstalled one spline too high.
Jack(Ky) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2011 at 8:53pm
They had to have been readjusted or someone put on some very loooong fenders.JP
