D-14 Knob |
EPALLIS ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Illinois Points: 1141 |
![]() ![]() ![]() ![]() ![]() Posted: 23 Aug 2010 at 8:53pm |
I just found a D-14 with a Woods RM-306. I see this large knob in the lower right hand corner on the instrument panel. Anyone know what this does? Not a choke or light switch, it plulls something under the fuel tank. Thanks in advance.
Rick of HopeIN ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Hope, Indiana Points: 1324 |
belt pulley engage knob
Brad MI ![]() Silver Level ![]() Joined: 12 Sep 2009 Location: Arcadia MI Points: 339 |
Belt pulley engagement control. If you don't have the belt pulley on the tractor and would like to sell the knob and linkage I'd be interested.
Larry Miller ![]() Orange Level ![]() ![]() Joined: 21 Nov 2009 Location: NWIL Points: 900 |
That control rod seems to be expensive - only saw one and more than I would pay. I got a cheaper PTO control rod from a WD or 45. Bend it a little, then cut center part out, over lap and weld to length. Pretty easy to do and covered up with the side panel.
I used to be young and stupid, now I am not young anymore.
Thanks Rick. I pulled the knob out and there is a belt pulley installed there but nothing happened. What should I look at next? Thanks in advance.
D-17_Dave ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Mocksville NC Points: 990 |
The crank lever for the belt pulley is made into the torque tube. If you have no pulley on the outside of the frame then there is nothing inside connecting the crank arm. It just hangs inside there. It would be nice if you couls post some pics and demintions of the linkage as I need this linkage setup.
RichinWis ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Deforest Wis Points: 691 |
That linkage and knob setup is very simple to make,if I can find the one I have I will measure it for you guys. Thanks Rich
There is what appears to be a pulley on the outside. When I pull the knob out the pulley does not turn. Is there another step to complete? Thanks in advance.
bigfish_Oh ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: West Liberty,Oh Points: 1226 |
make sure it is in the lever(if your side panels are hiding seeing it). let the clutch out.
1941 WC sat for 29 years,started & dynoed 27 h.p.
1957 WD45 Grandpa bought new,factory p.s.,added wfe 1951 WD, factory p.s. 1960 D14 HnMk IV BkHoe 4 sale 2014 HD Tri Glide 2009 GMC CC SLT Dually |
