D-14 heat houser
Harry up of Mi. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Harry up of Mi. Quote  Post ReplyReply Direct Link To This Post Topic: D-14 heat houser
    Posted: 19 Dec 2010 at 5:40pm
Just installed a Regal heat houser on my sons D-14
GBACBFan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2010 at 5:43pm
I'm thinking your son lives somewhere south of the UP. If not, you sure did a good job melting all your snow!
The installation and the tractor look great. I really like the grill guard with the bump out for the hydraulic pump. Nice!
are genuine." - Mark Twain
Post Options Post Options   Thanks (0) Thanks(0)   Quote Harry up of Mi. Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2010 at 5:56pm
GBACBFAN-this is west central Mo. temp today got up to 45 degrees. I and my wife are on our way to Az for the winter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2010 at 6:07pm
Nice looking snow removal unit, if he ever gets any. LOL  I dug my old HH out the other day. It seems I removed the home made bracket that holds the center up to the steering wheel support shaft. I think I'll wait for warmer weather and sunshine to tinker with it. I don't spend more than 20 minutes at a time on the 45 anyway.
Jack(Ky) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2010 at 8:35pm
I wouldn't mind having one for my ol' 14. I wonder if the front pump drains very much power from the tractor. I have a front pump for mine but some of the jobs I do with it takes about all the power it has.JP
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2010 at 9:09pm
Harry: Do you know what brand of loader that is? I have one like it and it does not have any identifying marks on it.   Dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote Harry up of Mi. Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2010 at 8:25pm
Dave
I think Freeman made that loader for Allis Chalmers, maybe someone knowes different. I do not know the model number.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2010 at 8:33pm
Hey, Harold, did you get your calendar before you left? You made September look like a pretty good month!
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2010 at 8:41pm
what type of brackets hold the center of the Regal up? I was warned away from Regal due to drilling needed for it, did you do any drilling?
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
Post Options Post Options   Thanks (0) Thanks(0)   Quote Harry up of Mi. Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2010 at 12:55pm
GBACBFAN
Yes, I have the calendars, they did a good job putting them together. I though all of the pictures were good, especially the Sept. one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2010 at 1:03pm
That looks like a pretty nice install there. A step back in time...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Harry up of Mi. Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2010 at 1:08pm
AC WD-45
The center support bracket bolts on to four bolts on the side sheet metal pieces, two bolts on each side. No drilling is necessary. This was on the D-14 with side entry. When I started it looked like  mounting was going to be a real challenge but it turned out not to be too bad.
Harry UP of Mi.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2010 at 7:12pm
Well, Harold, I'm going to let the cat out of the bag. Here's a pic of Harry's 1956 WD 45 on our local club tractor ride this past summer. We did a club calendar for 2011, and this is the pic for September.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2010 at 9:02pm
The loader on the D-14 would be an Allis ( Freeman ) Model 14.
The front pump is an 'Add On', usually only used on the Model 414 Loader with the Double Acting lift cylinders and Hydraulic Bucket.
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote Harry up of Mi. Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2010 at 9:58pm
The add on pump goes to a priority valve for the char-lyn power stearing and left over volumne goes to a two spool loader valve.
Harry UP of Mi.
Rick of HopeIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2010 at 7:59am
Most farms in my area in the 70s still had scattered properties.   If you had a heat houser on any tractor it made all the difference on those winter 'road trips' that came up too often.
This page was generated in 0.081 seconds.
