d14 gears |
Pipe
Topic: d14 gearsPosted: 08 Apr 2010 at 7:58pm |
what makes the d-14 jump out of gear and if it jumps out of 3rd and 4th is this also common or a sign of bigger problems . what would be the fix ?
norm [ind]
Joined: 16 Sep 2009 Location: BOURBON,IN. Points: 667 |
Posted: 08 Apr 2010 at 8:03pm |
have seen the nut come loose on the pinion shaft will cause it also was told it can be tightened from outside
CTuckerNWIL
Posted: 08 Apr 2010 at 9:56pm |
The most common cause is people grinding the gears. Over time the tooth rounder on the gear becomes a deep bevel and it will not stay in gear. If this is the case, replacement of the shifting collars at least, and worse case would be to replace both gears and collar. After splitting the tractor, you might as well fix it right.
Dale Hardtke
Joined: 12 Sep 2009 Location: Watertown WI Points: 171 |
Posted: 08 Apr 2010 at 10:28pm |
Rear half of a D-14 for sale S.E. Wisconsin (262) 719 3552
